please suggest good Speaker package for my AVR-X2600 - Denon
Hi velkumar, welcome to the forum.
Kindly describe the dimension of your room, listening distance, budget , 5.1 or 7.1 or what kind of system you are planning,
is it mainly for HT or also for music, what sound level you listen to.
If you can provide with details our fellow members would be able to guide you.
With warm Regards
Siva
5.1 would be fine for me. I have BOSE surround for setting up the ATMOS.
HT or also for music - BOTH
I'm looking for Tower setup. Because I Have Yamaha basic series.
You can Check out Indiqaudio's speaker, they have got great reviews, also a Group buy for the same is also on with good discount on offer.
I am using Mission Qx 2 as fronts and Qx C as Center and Lx-2 as surrounds with my old Denon 2309. Bought from HIFiMART. Very happy with the sound quality. U May consider those.
