Please recommend - HDMI Cable supporting 4k@120 HZ
rajivaryan1984
INDIA
Hi Friends,
Could you please advise on HDMI cables supporting 4k@120 Hz refresh rate. This is for my PS5 and Apple TV to be used with Denon AVR X4700H and Samsung Q80T.
Though I had came across some models in Amazon India but not sure if they are really authentic to support 4k@120 HZ.
Appreciate your inputs..
To see list of certified cables visit https://www.hdmi.org/
Earlier Chetan cables from India was certified. Not sure if they still have it.
I think Indian brand Kable Tech is also certified.
Of course Number of foreign brands are also approved by HDMI org
Hi Friends,
Zeniq is better than bluerigger and others .I m using zeniq,blue riggerandDHIVIS 10 MTS optical fibre.
Zeniq and bluerigger are shorter ones 1.5-2 mts.
Blue rigger is cheaper option at 400 rs while zeniq is at 2.3 k.
Zeniq has better reviews and 5* recommendation
Hi Friends,
Better to go for chord HDMI
Go for this support 4k@120hz and 8k @60hz
+1 for Zeniq. I am using it for last 3 months and works seamlessly.
