Tannoy HTS 201 5.1 for 42k, worth it?
Taga B 40s would be Fronts and would be connected there. The Center speaker will go to the center speaker posts and surrounds if purchased would go to those channels.
Only the Front speaker wires can use Banana Plugs or bare wire ends....one needs to be careful to ensure AVR is off when connecting the wires and the right set of bare wires goes into the channel posts properly without touching the AVR body or each other.
Thank you for the explanation... appreciate your time.
to which pins you will connect Taga Azure B-40 & Taga Azure C-40. if you done mind can you please let me know ?
The speakers are connected to the ports labelled Speakers, below the USB port. Each speaker requires 2 wires, one each for positive and negative terminals. These wires carry electricity as well as audio signal. So speakers don't need any other cables.
Speakers are usually connected using bare wires, no separate connectors are necessary, though, you can use banana plugs for convenience. For connecting speakers, you can use regular electric wires or specialised speaker wires. I'm using 2.5 sq. mm. finolex cable for front and center and 1.5 sq. mm. polycab cable for the surround speakers. Specialised speaker cables can be more expensive. What you need to ensure is that you use 100% copper cables for good signal quality. Both Polycab and Finolex are very high quality cables.
One last query, can you please let me know by any chance did you build your own Streamer (Pi Zero + Volumio )
It's less building and more like copying some files to a memory card and putting it in the Raspberry Pi. Volumio image is ready to go, you just need to set up the wi-fi network and point it to your library. I am using it for local streaming only, from my NAS. It does not support spotify free tier, so I use Echo flex for that. No support for Gaana or Saavn though, unfortunately.
thank yuo @gourav for the detailed explanation, learned a lot about cabling and different type of plugs.. much appreciated.
nd I don't think I'll be missing a subwoofer much. I'l
s as well. Else you will not have anything to compare and don’t know what to expect.
R you interested in JBL 5,1 package ??? Mint condition used ones available, 100 percent working, 90 percent cosmetics, # all original condition, no repair history # location Bangalore # shipping is possible all over India at extra cost
Hi Mahi, Do let me details of JBL 5.1 package. I am looking to do ATMOS setup with Denon X1600H/S650H whichever is available. I am also in Bangalore.
Please share your WhatsApp no # I send you original images & details,
