Hisense is launching U6G in India with Big Billion days (55", 700-nits, FALD at ₹60k)
Guess this is 55A71F model. This is not u6g, atleast not the US model, which has arc under AV ports
It's not. A71F is also sold in India. Also A71F doesn't have local dimming which this does.
There's no local dimming TV which is cheaper than U6G. Also specs are same.
Please don't make baseless assumptions without anything to back it up.
You have go inside "Audio Output" to see ARC. A71F doesnt have local dimming.
Guess model name of A73F, A71F, U6G are all same(HiSmart TV A4). Assumed the body is just replaced or something. Good if its not.
MEMC couldn't do a very great job on cricket on hotstar. But I havent seen any TV which can fix 24 fps cricket matches.
Also android 9 ootb and no update yet. On flipkart they mention android version as Q
Does this TV support MEMC?
any settings to change these things?
On the site it says it does but some US reviews say it doesn't.
I guess US version and Indian version is different.
Just placed order for U6g after considering Nanocell series, Frame, X80J. Honestly i wanted a Qled with good blacks and PQ, Dolby Vision and had a strict budget and no other brand had any decent options below 70k. U6g looks like a vfm product with excellent specs. just concerned about the warranty. any options of extending warranty or to get insurance? will be pairing it up with a LG SJ3 soundbar. Got it for 53k including SBI Credit Card discount and no cost emi option.
