suggestions for stabilizer for my tv upgrade and stereo amp
sand87ch
Kollam
I am upgrading my 43 inch tv to a Sony x85j 55 inch next week and will move this Sony 43 inch to my bedroom which has a 32 inch TV connected to a V Guard Crystal(2A) Stab.
I wanted to know 2 things:-
1. Is the current vguard crystal plus(3A) stabilizer which is around 7 years old sufficient for the 55 inch tv too or do I need to upgrade the stabilizer? please note its working fine till date.
2.If I can use the above stab for the new TV then would connecting my 43 inch TV to the existing V guard crystal(2A) stabilizer be ok?
The reason I ask is because i have a Marantz PM 6007 in my bedroom for which I am planning to buy a V Guard Crystal Prime 200(6A) or a V guard crystal Prime 150(4A)
and it would be convenient to reuse the already existing better stabilizers.
Also if I buy a new stab for the new TV then could I use the old vguard crystal plus(3A) stabilizer that I have just for my Marantz PM 6007?
vertex hifi audio stabilizer
well i have seen this in forums but am trying to make sense of the existing stabilizers coz i was planning to buy the 6A version as the vertex seems to be a bit costly.considering that i would travel out of india next year and theres no one else probably going to use it.
Thing is if i buy a new stab for the tv then one existing stab becomes unused and i was thinking of using eithwr the 3A one or ifthe tvs can be used with existing stabs i would go for a new 6A stab.
Sorry for confusing the hell out of u all.
Frankly speaking the Vguard stabilizer is not so great & the accuracy of voltage stabilization is +- 10 units up or down & may be ok for the TV. I have the Vguard digi 200 smart & a Krykard 3kva stabilizer. The Krykard is + - 2 units up or down but mostly accurate at 230 V.
The 65 inch TV & set top box is connected to the Vguard. The rest of the sensitive HT gear is connected to the Krykard. Vertex is also good.
