Monitor
Model name............... Philips
Windows description...... Philips 105S (105S2)
Manufacturer............. Philips
Plug and Play ID......... PHL0001
Serial number............ n/a
Manufacture date......... 2007, ISO week 48
EDID revision............ 1.3
Input signal type........ Analog 0.700,0.000 (0.7V p-p)
Sync input support....... Separate
Display type............. RGB color
Screen size.............. 710 x 400 mm (32.1 in)
Power management......... Not supported
Extension blocs.......... None
DDC/CI................... n/a
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.617 - Ry 0.334
Green chromaticity....... Gx 0.283 - Gy 0.590
Blue chromaticity........ Bx 0.143 - By 0.086
White point (default).... Wx 0.284 - Wy 0.295
Additional descriptors... Color management
Timing characteristics
Horizontal scan range.... 31-80kHz
Vertical scan range...... 60-85Hz
Video bandwidth.......... 100MHz
CVT standard............. Not supported
GTF standard............. Not supported
Additional descriptors... None
Preferred timing......... Yes
Native/preferred timing.. 720x400p at 85Hz (16:9)
Modeline............... "720x400" 35.500 720 756 828 936 400 401 404 446 -hsync -vsync
Detailed timing #1....... 1280x768p at 57Hz (16:9)
Modeline............... "1280x768" 68.250 1280 1328 1360 1529 768 771 778 790 -hsync -vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
1024 x 768p at 60Hz - VESA
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
640 x 480p at 85Hz - VESA STD
800 x 600p at 85Hz - VESA STD
1024 x 768p at 85Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1360 x 765p at 60Hz - VESA STD
Report information
Date generated........... 7/17/2010
Software revision........ 2.52.0.857
Data source.............. Registry-Active
Operating system......... 6.1.7600.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,41,0C,01,00,01,01,01,01,30,11,01,03,68,47,28,78,0A,28,8E,9E,55,48,97,24,
16,48,4B,AD,CE,00,31,59,45,59,61,59,81,80,8B,C0,01,01,01,01,01,01,DE,0D,D0,D8,20,90,2E,10,24,48,
13,00,C4,8E,21,00,00,18,A9,1A,00,F9,50,00,16,30,30,20,37,00,C6,90,21,00,00,00,00,00,00,FC,00,50,
68,69,6C,69,70,73,0A,20,20,20,20,20,00,00,00,FD,00,3C,55,1F,50,0A,00,0A,20,20,20,20,20,20,00,E7
