jeevabobby26
Experts can anyone tell how much this will give improved quality over the RCA.
Com World CMD-HDX6 Professional HDMI Video Converter for PAL to NTSC HDTV video conversion, convert PAL 1080i to NTSC 1080i, hdmi conversion between PAL 1080P and NTSC 1080p, PAL to NTSC HDMI converter CMDHDX6 HDX6
$269.99
Connections:
RCA (composite) or S-Video (SVHS)
HDMI Output - up to 1080p (NTSC)
Specially designed to work with any Hi Definition source like Satellite Receivers, cables boxes, DVD players, DVD recorders, Digital HDV Camcorders, etc...
Use it for:
LCD or PLASMA TV: Take your NTSC (American) HDTV to an overseas PAL country. Using the high definition quality conversion of the CST-65 you can convert PAL TV signals to NTSC HDTV for viewing on your existing NTSC LCD or Plasma HDTV. Eliminating the need to buy a new multi-system TV set. Local PAL TV tuner like a Cable Box or Satellite Receiver is required. This converter does not tune channels.
International travel and relocation:
can use your video equipment with it while traveling or relocating to a country using a different TV system. can install it on ships, planes and for many industrial and business applications.
Camcorders: Use your PAL HD camcorder in the USA. can also convert movies from your camcorder.
Game Systems: Use your Hi Definition PAL game system like PS3 or XBOX 360 on a NTSC TV.
Satellite, Over the air broadcast or Cable TV conversion
Excellent features list:
No audio or video delay! Converts in real time.
Use your PAL/Secam HD (hi definition) equipment in a NTSC country
Very easy to use, just plug and play
Crisp, clear, sharp converted video. Exactly as your original. You will not notice any video degradation after conversion! That is how good this model is.
Compatible with ALL Mono, Hi-Fi Stereo, Dolby Digital and DTS equipment.
Stand-alone and stylish compact design excellent for portable application also
Automatically convert signals from PAL/NTSC to NTSC
Detects input automatically between: PAL and NTSC and converts to NTSC.
For example:
- Convert PAL Camcorder which has RCA outputs and watch it on your 1080p HDTV
- Watch PAL TV channels on your American NTSC HDTV.
- Watch PAL broadcasting on your American NTSC HDTV.
Excellent conversion characteristics such as:
Pioneering technology allows this converter to stay in the digital domain throughout the conversion process with fully digital decoding and encoding
No field memory - New Digital technology provides direct conversion without any signal loss!
Input RCA or S-VIDEO (PAL or NTSC)
Output Resolution: up to 1080p (NTSC)
Digital Line (525 <-> 625 Lines) and 50<->60 field conversions
Built-in Time Base Correction (T.B.C) for signal synchronization
Unit Specifications:
Dimension: 230mm(W) x 130mm(D) x 30mm(H)
Weight: 380g
World Wide Power supply. UL approved 100-240 50/60 Hz auto switching power supply for use anywhere in the world.
$269.99
Connections:
Use it for:
For example:
Weight: 380g
