1st Home theatre Xperience
Novice
India
Hi everybody,
First I used F&D speakers which worked well for 6 months. From then I have been usin Panasonic sc pt75. Its ok with speakers but woofer Bass is too high at times where it becomes more irritable and necessitates volume reduction. But for the budget less than 9k I think it serves the purpose.
I saw an ad in big bazzar hyderabad where they offer onkyo speakers for 19k. Its just speakers and recievers are not included..Is it worth buying?
Kindly reply...Thank you all in advance...
Can you specify the model? I think they should be of 5000 series. Onkyo are best known for their receivers and not speakers. So if you need an entry level htib, go for hts3300 or 3400 from onkyo of course from an onkyo retailer with little more
investment
