2.1 speakers under 5k
Strings
Hyderabad
Hello everyone,
I'm looking for a compact 2.1 speaker system for my 12*10 size bedroom with all the features like Bluetooth, FM, Aux, USB etc.
Tight bass and clarity are the main criteria. Having physical volume, bass and treble controls on the main unit will be preferable, however, its not mandatory.
I don't want to increase the budget any further unless it is really worth it.
All suggestions are welcome.
Thank you all
Hello everyone,
Thank you all
If you are comfortable buying used, check this link.https://www.hifivision.com/threads/harman-kardon-soundsticks-wireless.70669/
It's a bit above your budget at 7K but it would be worth it.
Hello everyone,
Thank you all
It is a little difficult to get a good 2.1 with the features you require under that budget...however you can look at preowned stuff.....check olx also....
Check Philips / Sony / LG if they have such offerings...
https://www.croma.com/philips-mms40...MIhMWIofiW3AIVmTUrCh2_lQeWEAQYAiABEgL6BfD_BwE
https://www.croma.com/lg-lh70-b-2-1-channel-multimedia-speaker-black-/p/194383
Audition and decide
Not sure if something like Portronics soundchief would interest you.. Anyways, take a look at these.. Interesting part is, it has co-axial input..
Link for the same - https://www.portronics.com/speakers/sound-chief.html#
Thank you all for your responses guys. The soundsticks looks good but I would like to go for a new system. Also, I should mention that I had a FnD A521 2.1 which served me well for 3 years, now I feel the need to upgrade to a better system with more features.
How are the below options-
1.Edifier XM6BT
2.Swans M10 (A little over my budget)
3.Panasonic HT21 (Also, over my budget)
4.F&D 550X
You can suggest other options as well.
Swans are quite nice and some members have used them...still have them....
Audition and decide...compare the specs...and decide
Yes. Even I have heard good reviews about the Swans. However, I'm a little skeptical about its bass performance. I mean it has only 5" sub which I feel may not be enough to produce good punch. I could be totally wrong about it though. Perhaps our FMs who are using it can throw some light on it.
