2 Source 1 Pair Speakers?
riteshmadhok
I want to connect 2 sources to one tower speakers.. I got a pair of tower speakers that are connected to my Stereo amp, now i want to connect the same towers to my AVR also and use as front speakers when I am watching movies. Is this possible and if it is please enlighten:indifferent14:.
I followed the simple solution of spirovious to connect my AVR and Amp to single pair of speakers. I did the wiring directly to the switch instead of binding posts. It is cheap,quick and simple solution.
if your avr has preouts, connect that to the amp's input.
There will be two preamps in such a setup
Within few hours you made a speaker selector switch? :eek:
pl post pictures of the switch set up
