32 Inch Panasonic LED TV
sandip
Pune
Hi, I am planning to buy Panasonic TH-32X50D LED TV. I don't know much about LED TV's. Please suggest if my choice is good
Coz its an old model, go for always the latest one's out there buy an E5
Sent from my GT-S5830 using Tapatalk 2
not always new models must be good....new batch of pulsor 150cc is a weak child comapared to the older batch..
a 2 year old launch very hit model is always good than a just lauched unknown performer...
anyway at 32 inch toshiba has some really cheap at say 17k..pana has also around 21k..check for those..dont go for full hd at 32 inch..cant distinguish at 32 inch betn full hd and semi hd..better to save the money and go for semi hd 32 inch..
model completly upon ur demo experience..ur chioce of picture..but pls no full hd..
if its a long term investment I suggest invest little more and get 40/42 inch..bigger is better in display(if our pocket allows)...
semi hd plasma pana and sammy 36k within...and full hd lcd from toshiba...41k I think...in showrooms
sony 40 incher is avilable within 38k but in gray market...
if seriously decided 32 inch..then must be semi hd....
You are saying that it better advised to go for semi-hd for 32 inch on what respect
a. Standard Definition
b. High Definition
I know currently only 20 channels are in High-Definition but in future (within 2 yrs) i feel all the popular ones will come out with High Definition.
So for full HD viewing u are suggesting a semi-HD screen . I am not able to understand this.
b. High Definition
nono I am not saying it with respect to channels whether hd or sd..whatever.
at 32 inch size at a distance of say 5 ft we cannot differenciate between 1080p panel or a 720p panel....u can experiment it play a blu ray matarial that is original 1080p in a semi hd and full hd of 32 inch size side by side..
and yes the hd channles also are not 1080p they are 1080i..so its always a much beter desision to go for semi hd at 32 inch...because the difference cannnot be enjoyed at 32 inch so why pay extra...
What would you advise if its 8-9 ft for SD channels ..semihd or full hd ??
only for SD channels I suggest 29 crt...super value for money....no offence just my idea:)
and in 32 inch lcd catagory undoubtdely semi hd......never full hd at a distance of 8 ft and mostly sd channels.dont go for my word.experiment it in a showroom....
its impossible to tell whether semi or full hd panel at a 8 ft ditance that too with sd material
but yes if the budget of say 35k is ready and planned I must suggest to go for 42 inch semi hd plasma from pana or sammy........display is bigger is better if our pocket supports:D
This is the 2012 model of IPS based edge-lit LED TV. I have seen this TV. This TV looks good. The price is 32-33K. You cant get better TV than this for the same price. The PG is also good. It detect USB pen drive and USB HDD but does not read all format.
Overall I can say that This TV is good.
