32 ' LED TV Buying Guide
niharvora
Indian
Hi i am Nihar Vora.
I wish to buy a LED TV under a budget of approx. 30-32 K.
My Min Req. are:
1. Good Pixel ratio / density of the screen.
2. Good brand.
3. Supports all external inputs like usb drives, external hard disks, dvd input.
4. HDMI input, VGA input.
5. On the opposite side of the television is the window which would result in direct sunlight falling on television.
6. Viewing distance is 8-10 feet.
7. Viewing angle should be atleast > 135 degrees.
8. Low on power consumption.
9. Good after sales service.
Go for Toshiba Thinking LED series.....it has all the features you are looking out for. I use the PU series and it is indeed value for money backed by 3 years warranty.
You can do a bit of window shopping and visit a Vijay Sales / Ezone / Croma etc and see the models of TVs on display, hear the sound, view in all angles, check connectivity options and ofcourse warranty.
End of the day it matters what is your taste and budget.
Just check out Panasonic 32E5 if it is available anywhere. It is an awesome 32 FHD Semi-Smart TV. I think it will come around 30-33k.
