32" LED TV :: Sony
hpsangha
Earth
Thinking of buying 32EX330 Sony Direct LED
whats your suggestions guys
price a bit on higher side
Can someone suggest pro cons of this
and also other models for 32"
Other than form factor, i.e., cool shape/thin size and inherent brightness of LED, you will not derive additional benefit in 32" size. Why not consider LCD instead? You will save a lot of money. Consider Sony BX series.
hey my first post here.. :)
will be buying 40" led tv(sony 40ex or sammy 40eh) wanted to know which video clips to to take for checkin pic quality...
it would be helpful if u can give the link of videos.
thanks.
CCFL back lit LCD or which we commonly called LCDs have lower contrast ratio,less bright and lower panel life.
While LED lit LCD or which we commonly called LEDs have higher contrast ratio, more bright, higher panel life and more vivid color.
If you have option to grab a LED then always go for LED.
