40+ Smart Full HD LED Suggestions?
dorkstar
I am looking for 40+inches Smart Full HD LED. I am confused between LG and Panasonic. Both had options around 60K in stores.
Panasonic seemed to have more real colours(Observation while watching a match) still the artificial colours in LG was a better viewing experience for the match. Somehow found all other(Samsung and Sony) PQ very similar to LG
Panasonic had 3yr warranty but the store guy said it is only 1 year comprehensive warranty and rest 2 years only only service visits are covered. Anyone knows about this?
What would you guys suggest? Any other TV with the same criterias and around 60k budget?
Sorry don't remember the model numbers. Will probably update them tomorrow.
Go for the Sony 42W650A. This is the best TV in this price range - period. No LED TV from either Samsung, LG or Panasonic comes close in PQ under 60 K. This Sony uses a SPVA panel from AU Optronic and has excellent black levels of .022 cd/m2 and and input lag of only 6 ms.
You will not regret your decision.
If Uve liked the panasonic...go for it, I believe you saw 42E6D...which IMO is a brilliant set n has got rave reviews all over the Internet for its fab and natural PQ from HD or SD sources.
It's also got an inbuilt wifi, u can put the smart features to full use from get go.
I m hearing this for the first time, 1 yr comprehensive n 2 yr service visit....this sounds more like a car warranty thingy than a TV...lol !
As far as I know...it's a complete 3 yr warranty....others can confirm.
think so,It's also got an inbuilt wifi, u can put the smart features to full use from get go.
