42 inch LED/LCD/Plasma
bigdaddy24
pune
Hi Guys
I want to purchase a 42 inch TV
I want to know should i go with an LCD or LED or Plasma.
I want to purchase a tv with 3D capabilities but i guess it goes beyond 1L :sad:
I dont want to confuse myself because there are a lot of options available.
I Just want some replies from you Guys and some specific models that you are using at your place.
My Budget will be till 80K
I will check those Models out and buy one of them.
I hope to get some good responses based on your own experiences.
I will mostly watch hi-def movies on the TV.
Sorry about the long post.
Hi Guys
Can you please shower some valuable comments on my post please.
I need to buy a TV by the end of this year.
Hi my vote on the panny 42V20 again. Save you some money to buy a decent BD spinner. or a samsung 3D model is available for abt 120000 MRP, your price should be less, check out during new year.
Hi Big Daddy24,
Last year I had bought Panasonic G10 42 " it was very good, this yr one of my friend has bought V20 42 " its better and it will cost you in the range of 64-68K. I would recommend Panasonic V20 series
Well look at the panny V20D or new LG LED series ..... If you go for Panny V20D you can save 15 k and buy a Bluray player :)
I Guess Panasonic is the choice of the masses.
I will check that out.
Do you recommend Samsung plasma as i have read in these forums that they are not good?
Well look @ Samsung for LED,LCD not for plasma unless you get a great deal...
well i feel u aspire to own a 3d tv in future and at the same time you need some big screen entertainment now
your corpus is 80k
in my opinion split it to 35k and 45k brackets
with 35k buy a panasonic plasma with 3 yrs warrenty and rest asured for 3 yrs
save the 45k and after 3 - 5 years when ur bored of this buy a 3d tv
that costs bout 2l now will be cheaper by then ....
Sound advice, think about it, but check which screen size you would get @ 35K. I recently bought a Sony EX 600 LED, 40" for 80K and the price has already dropped by about 5K in a span of about a month or slightly more.
which pana for 35k with 3yrs warranty?
Panasonic TH-P42X20 is available for 35-37K from Panasonic Brand shops.
But there is a lot of panel reflection with moderate to high ambient lighting, but with low to nil ambient lighting the PQ is very good/great, beats every LCD/LED Tv's.
Hi Guys
Thanks for all the replies.
I will check out these models.
I know 3D tv wont be possible at this time.
Let me know of your final choices guys.
Hi Guys
I went to panasonic shop to check the V20 and it was good.
I also saw X20.
X20 was priced at about 35K and V20 at about 68K.
Which model should i go with?
there is a huge difference in price though both are 42 inch.
and is the price of V20 ok?
Also i checked samsung LCD and the brightness of those TVs were awesome.
So should i purchase the panny plasma or samsung LCD
I will use the tv for watching HD movies most of the time.
No DTH.
Please reply soon.
I have to finalize the deal.
thanks kittu
but what is the difference between V20 and X20?
Is spending 30-35K extra worth it for V20?
I did not see the X20 in motion so I can not comment on it but the V20 is superb..... And just compare the specs on panny india website.... Take a demo of both TVs.
