MaheshKumar
Hello Everyone,
I am from Chennai. Needed suggestions for 5.1 setup in bedroom of size 10 ft x 12 ft (size mentioned is actual carpet size after wardrobe done). Can spend a max 80K for audio. Haven't thought of the budget for Projector/Screen as it will be added later. 14 guage Amazon basics wiring already done.
Following are my preferences
AUDIO
1. 85% listening to Quality music (FLAC, Apple loseless), 20% movies
2. Not so keen on Atmos (because of Ceiling height, small room space, budget) , 5.1 is sufficient but good quality music is a must
3. NO floor standing speakers. Infact Front L/R & Center speakers can only be placed ABOVE the projector Screen. Both projector and screen will be added in future. See the attached images.
I did auditioned Polk TL1600 5.1 and Klipsch 5.0 reference pack. Liked Polk than Klipsch. But on further research started feeling that Polk TL1600 is more good for movies than music. Many suggested to choose individual speakers over packaged systems if music is the preference.
After reading many suggestions @ hifivision.com, narrowed down on Yamaha V485 AVR. Am ready to even start with just 3.0 setup and later add Sub & Surround when budget allows.
VIDEO
1. Low on BUDGET. 4K not required, FullHD is enough.
2. See tha attached images. Distance between the projector wall and screen is 10ft. So after fixing the projector, distance btwn Projector lens and screen should be just 8 to 9 ft.
3. Screen of size 6.5ft W x 4.5ft H can only be fixed on the wall as I have wardrobe next to screen.
4. Max budget for projector+screen 25k to 40k (not sure if it is sufficient)
Please suggest on speaker combinations, projector
AUDIO
VIDEO
