55 inches TV which to buy?
djbobby10
Which is a decent TV 55 inch TV to buy in the budget of 75k do you think? Need to use for Firestick, Tatasky etc. No gaming. Sound will be Bose 500 soundbar with it's Subwoofer.
The best in your budget is the Samsung Frame 2020. Within 1 lakh, we always struggle for options in India. Or if you are willing to do further market survey, you're welcome. But frankly you wouldn't get any satisfactory alternate.
Try Amazonbasics during offer time or Mi (service is good) and all ~Rs.50k tv are assembled in Andhra only.
I have been using a TCL 8 series 55" TV for the last one odd year. It is 4K and has Android installed. It also supports eARC.
Today paying anything more that 1000 per inch for a 4K TV does not make sense. The difference you will see in terms of video and audio does not justify the price difference. The TCL's video and audio output is on par with most models from the likes of Sony, Samsung, etc.
What is the model number for this TV?
C715 and C815 are good TVs too.
There are many companies but most famous brands are which provides all the type of TV
  • LG CX 55-INCH LED TV.
  • SONY A9G.
  • SONY A8H.
  • SONY X95G.
  • SAMSUNG Q90A 55-INCH NEO QLED TV.
  • SONY X90H.
  • SAMSUNG Q80A 65-INCH 4K QLED TV.
  • LG 55NANO86TNA
You can check all the above TV according to your range.
