Hi Guys,
I am looking to get a 65" tv for my parents living room. The TV usage is mainly Tata Sky HD/SD channels and little bit of streaming apps. The room is bright with 12 feet viewing distance. They have been using Sony Bravia 42" FHD tv for last 6 years. Looking for a TV with the best possible picture quality, should last long and provide good service when needed. The budget is up to 1.2 lakh. I have found Samsung Frame 2020 , Sony x8000h and HiSense U7QF as possible options under the budget. I was considering Toshiba U7980 as well but it is not available at my pincode. Let me know your thoughts on which one (out of these or any other) will be the best 65" tv under 1.2L.
SD channels will look terrible on all 4K TVs, so you will have to live with that. For mostly Tata Sky usage Toshiba U7980 (H8f) is the best choice instead of spending 1.2 Lakhs. Rtings shows that all these TVs have same rating for 480p input. Just ask your local Reliance Digital to get the TV, they will get it in 10-14 days. If you are still not able to get Toshiba then go for Samsung Frame 2020.
