8ohms Home theater speaker - Under 30k
Reegan
India
Looking for suitable home theater system for Denon AVR X550BT. Budget under 30k. Couldn't find anything online shopping sites. Pls suggest.
If you want budget 5.0 setup, you can consider :-
1. L/R yamaha tower 8390
2. Yamaha NSP51 for center & surround
You can add subwoofer later.
If possible you can audition the above speakers if you have a yamaha dealer in your location.
All the best,
