A first Hi-fi system with Saptak Acoustics Rediscovery speakers and O&B DMB 2300 amp
The ear piercing sound he is suggesting is from the forwardness of the ATC in the mid range, its slightly less in the 3-way design but thats more or less the ATC sound. Having owned the SCM11 for almost 3yrs now and counting and also hearing the scm20 and scm40 on other occasions, the lack of low end in the sealed design and the tweeter being a few DB's lower than the mids makes the sound more piercing or forward for someone looking for a more balanced sound. Toe-in to the listening position definitely helps but the sound still remains mid focused, The soft dome tweeter is just too soft to offend any ears. I have tried the ATC's with accuphase E-270, sugden a21se signature, eam lab musica 102i with matrix, audionote and lumin dac. The results were the same with the mid range having the tendancy to come at you and sound forward. With the accuphase in play the tweeter just left the party even before it started, it was all mids jam with accuphase playing.
You used all the wrong amps with ATC and then you complain. You need more current to drive an ATC. Mine came alive only after I fed them with 300W/ch monoblocks. There is absolutely no ear piercing highs or fatigue if you setup an ATC correctly. If your chain has a flaw, it will show up. Could be the amps you used or your source.
If your listening levels are 65-68db you donot need a 300w mono block to drive any atc speaker. No where did I mention the high's to be piercing please read again as to what I have written. More watts can make your speakers play louder but it cannot change the sound of the speaker.
It does matter. I am saying first hand as I had a 125W/ch McCormack DNA power amp earlier and it struggled to drive the ATC, made it sound exactly as you say - upper mid range forwardness. The very same amp is now working beautifully driving a pair of dyns in my second system. This is quite a high current amp that had driven punishing speakers before but failed with the ATC.
ATC needs current - a lot of current. None of the amps you mentioned - sugden which is a 20W pipsqueak, or an accuphase e270 which is their entry level and again has a quasi compromised PSU making it lack drive or the eam integrated will do justice to this speaker. It needs current and a lot of drive. Once you give it that, it really sings. The electronics the speaker requires probably costs as much or more than the cost of the speaker.
There is a reason why ATC mentions 75-300W as the power range of the SCM19 that I own - it absolutely needs the grunt. The power reserves help it. Most people discard these speakers without even bothering to put the right amps on them and then complain.
It Doesn't end there, it needs everything upto a certain standard. Gryphon Diablo and ATC synergy is absolutely fantastic, as good as McIntosh with B&Ws or SFs. Class D (Peachtree Amp500 in my case) will show its weakness in favor of class AB.
The upstream electronics play a crucial role, I had to get rid of RPI based DIY Streamer options, Most of AliExpress based power cables and ICs as they were showing their weaknesses. If Recording is bad it'll be glaringly evident, Couldn't Stand Topping DACs , Terminator all the way. ATCs are typical Audiophile Speakers, invest in ATCs, only if you are willing to invest in all Good Quality components & Room Acoustics. But once it’s done, it’s hard to to beat the SQ upgrade. It doesn't lack bass or HF response once you match components of good calibre.
@manditri thats very good setup you've put up Congratulations , Invest in a 2 Compartment Rack for DAC, don't keep DACs on Power amp. Your next big upgrade should be a R2R DAC, like Gustard R26 which is a Good Streamer, DAC and Preamp with Remote. Also you could take advantage of XLR ICs.That should be a setup to challenge most of Midfi Offerings.
I still have the speakers with me, you still haven't read what I have written or maybe not made the effort to understand it. The power reserve does help alot as you pointed but that reserve will not change the sound of the speaker. The difference here lies in the fact that I have posted my comments above after using all this stuff and still owing it, you on the other hand are commenting on these brands through your assumptions on reading specsheets. Good for you if you like your ATC.
So when you don't have a point to contend with, you end up name calling?
I own the SCM19. It is still in my listening room - I've tried five different amps with it and in the end I settled for a pair of big monos as they sound the best with them.
Having owned both SCM19 and 19 Actives, I can easily vouch for getting the amplification right for the ATCs to sing. With Actives, you have that synergy and just need to get the preamp right.
If you dont want to play around with the amplification, get the active versions and a good preamp. For me, ATCs are highly neutral, brutally revealing speakers that needs good source components to really shine. But once you have everything sorted, you can really enjoy them.
This is so so true. Way too many times people discount these speakers but the they are doing is that they are revealing speakers are doing is revealing issues in the chain. Source, pre, power everything needs to be absolutely sorted else they will not sing.
My audiophile journey started when I saw the obsession my dad had. His most ultimate system which was his last and was a very painful when we parted ways with it was when he owned the Bob Carver Amp and Pre amp / Marantz cassette deck / Cd Player and eq I dont quite remember the brand and soeakers were Jamo. Even at a very young age he never stopped me from using such a High end system. He had given to me the full freedom to enjoy them. That became my obsession and Instarted off with Bedroom systems like Sharp / JVC / Sony / Kenwood
Slowly it fizzled out and I had hot myself the Nakamichi soundspace 5.
Somewhere in my heart I still wanted to build my system and I started - I would say I am now happy with the Harbeths which is now chained to the O&BSs 2150, I am so Happy with the synergy now with the ss2150 and harbeths they get along very very well - Thank you @⁨O&B⁩ @⁨Self Voda⁩
I am not so technical but I do appreciate the music which is classical.
I have waited almost 16 years to get into this hobby. And finally decided to take the plunge this year.
My hunt started with speakers as usual but amp was the first component I finalised. Came across O&B amps on HFV and got in touch with Aniket(@adas). I had the chance to listen to a pair of ATC SCM19s being driven by an O&B DMB at a FMs home. Built like a tank sounded even better. Chose a 150W@8ohms pc in a dual monoblock configuration. At the same time I was still deliberating about speaker choices and the decision was not firmed up. I was considering following options- ATC SCM19, SCM11, Sonus Faber Sonetto II, Monitior Audio Gold, Wharfedale Linton, IndiqAudio Mishra. Was discussing my speaker choices with Aniket and he pointed me to Suman Jana(@smnjn) of Saptak Acoustics. Suman makes 3 different speaker models. He shared measurements, build details, enclosure and component details and costs involved. Based on my budget I decided to go with the Rediscovery Towers.
Both Aniket and Suman promised delivery in roughly 2 months. Paid up the advance and waited.
The speakers arrived packed in layers of foam and bubble wrap. A week later the amp arrived equally well packed. My 11 year old kid was around to help when I was hooking up the system. But at the time it was hard to tell who was the kid. Below is a quick review. I am winging it mostly but these are as objective as I could be with my observations. Reviews and opinions about hi-fi gear and SQ are very relative to what the individual has experienced earlier.
Speakers- Saptak Acoustics Rediscovery Towers​
The speakers come with real wood veneers. Suman offered choices of veneer and I went with coffee walnut. The veneering is really excellent and high quality. Multiple layers of polish and pu gives a rich look and the edges are matched well. Enclosure is built from 1in HDF to keep resonances low. Crossover components are from Jantzen like superior Z caps and aircore inductors. Internal wiring and connectors with Oyaide, Choseal and Aucharm. Suman also builds interconnects and speaker cables with these brands. More on that later. Drivers are both Scanspeak from Revelator series crossed over low at 1600Hz.
View attachment 79503View attachment 79505View attachment 79502
Out of the box the speakers sounded great. Highs and mids were smooth without any hint of being shrill or shouty. There was enough grunt in the low end. But everything was so cohesive. The initial amazement was obviously a bit of rookie rush. So I waited for some run in to happen before writing this review.
- The highs are very detailed with good extension. I never felt any ear fatigue. Bells, strings, cymbals and the likes are revealing yet beautifully warm and smooth.
- The mids are sublime. Probably tweeters ability to crossover very low allows the mid woofer to shine so well. Vocals especially female vocals(Diana Krall) are phenomenal. Together the highs and mids create an extremely natural atmosphere that is true to the source. Though I feel the lower mids are not very pronounced. Suman mentions this will become better after the speakers are run-in for at least 240 hours. At this time they have run-in about 50 hours.
- Bass was a surprise. For a 2 way with 7in mid woofer the speaker can go quite low(~32hz). I can clearly hear stuff even lower like 25hz but probably 5-6db down. Its not quantity or thumping bass but the quality, very musical. I was listening to Awara Bhawre from the movie Sapney. Never knew AR Rehman's music had such quality bass in the track. Then another track- The Plan by Travis Scott from the Tenet movie sound track. Felt like slabs of bass passing through me. But definitely won't shake the floor. And the speaker needs proper positioning or adjustments with the listener's seating to avoid standing waves or boominess. I was experiencing this between 70-75hz.
- Imaging, instrument separation are quite good. May lose some composure in busy sections of a track. But thats a given trait with most 2 ways.
- I have a small room- around 160sqft and the speakers are kept just 7ft apart. Probably not enough separation to experience a good soundstage with floor standers. Tried Chesky records ultimate demo, track- Britten: Festival Te Drum. The choir actually seemed to sing from a height. Allan Taylor's The Tennessee Waltz is equally awesome.
- Transients and dynamics are nice- Prodigy(Pele soundtrack), Mombasa(Hans Zimmer, Inception).
- Quite unforgiving to poorly recorded tracks. But if well recorded, even cheesy bollywood numbers are a charm.
- One thing kept sticking out with these speakers. The coherent, natural and life like reproduction. The speakers have the ability to disappear. Very pleasurable when music envelopes you entirely.
Beside the choices of drivers and enclosure design, I strongly feel the magic is in the crossover design. Suman has done an excellent job. Some might think the speakers are high and mid forward. They are very balanced in my experience. I kept comparing their sound with my headphones and the speakers sounded equally accurate without any coloration.
Amp- O&B DMB2300 dual monoblock amplifier​
I wanted an amplifier which had lots of clean power even for demanding speakers. I do not want to change or upgrade the main piece of equipment powering the music often. Goal was to get something around 100w@8ohms pc. Another requirement was- I didn't want the bells and whistles like inbuilt DAC, streaming, phono, preamp etc and just keep it clean. My search led to mostly pricey monoblocks. After coming across O&B amps I was quite interested looking at the specs and the competitive pricing. Auditioning the amp was what helped me finalize the decision.
View attachment 79506View attachment 79507View attachment 79508
I chose the DMB2300 Dual Monoblock Power Amp in class AB topology. 150w@8ohms pc with individual power supply sections for each channel. Class A operation- 20w@4ohms. Offers both balanced and unbalanced inputs, selectable HPF@20hz, damping factor- more than 800. Entire case is built for heat dissipation. Weighs about 25kgs. Much of that weight comes from a large torroidal transformer inside. Black finish with cool blue VU meters and a green power button gives the amp bit of a McIntoshy vibe. Though I wish it came with an option to dim the VUs for night time listening. Buttons and switches are very tactile and feel solid.
I do not understand amplifier electronics much and I am not experienced in differentiating sonic characters of amplifiers from various brands. But I believe Aniket has built a power amp of high standards. Much of what I experienced with the speaker's ability to reproduce music was a direct result of the amp's prowess to drive 85db sensitivity speakers with complete authority. Switch on the amp and a host of protections relays get into action. At normal listening levels the amp hardly went beyond -40db on the VU meters. Aniket says this is still class A territory. After long hours of running, the amp doesn't get hot, not even warm I would say. Neither did I get any audible hum or noise even at high volumes. The presentation of the amp and the speakers together is very clean with a dark background. Makes it quite good for listening at low volumes at night. Together they make an extremely capable mid-fi system.
DAC- Topping E70 Velvet(AKM AK4499EX)​
I chose this DAC solely based on online reviews. Some reviews have even compared it with higher end DACs twice or thrice the price. I wanted something that was not too entry level although I have plans to upgrade to a better DAC at some point. Very smooth with decent bass. I have played around with the filters it comes with. Couldn't tell a difference. IR remote is a bummer as it needs a short clear line of sight to work accurately with the unit. Nothing more to add here. Overall happy with it's performance.
Cables- Saptak Acoustics Interconnects and Reference speaker cables​
Suman makes some excellent interconnects and speaker cables. The Interconnects are made from Aucharm rca cables and connectors. The speaker cables are made from multiple 20AWG choseal cables twisted together and wrapped with insulation jackets. Initially I was using some 14AWG OFC cables from monster cable. The quality of the Saptak Acoustics speaker cables became apparent when I replaced the monster cable with them. Although the cables need some 10-12 hours of run-in, the difference was immediate and impactful. Everything opened up, started shining more. Cleaner background. And the music overall gained better presentation and soundstage. I thought it was just placebo. But then my septuagenarian mom walked in claiming the music sounded better.
Source- Apple Music​
Source is currently Apple Music Hi-Res Lossless. And I play it directly from a Mac(with Lossless Switcher) or from an Android phone using a long USB cable connected to the DAC. Bit of inconvenience, but as long as I am on Apple Music, this is the only way I can get the best quality.
I stand somewhere in between "music lover" and "gear lover" categories. So goal was to build a solid baseline system with a speaker and amp combo that is above the entry level stuff. Keep my music enjoyment in play for years. Gradually will add or upgrade other parts like sources, dacs, cables etc. First order of things is to get some good quality av rack. After spending considerable time with the system, I am convinced that these components are step in that direction.
Hi, could you please help to know roughly budget of DMB 2300 and Saptak Speaker?
Rgd-Vinay
