As you know, normal .srt files will not work for SBS and OU 3D files as subtitles are needed for both the frames. Here is a small guide to create subtitles for SBS and OU 3D movies from .srt files.
Tools you will need
1. Java Runtime Environment
2. BDSup2Sub
3. 3DSubtitler
4. MKVtoolnix
BDSup2Sub.jar is a java file and you need to install JRE to run it. BDSup2Sub and 3DSubtitler don't need installation. MKVtoolnix can be downloaded as an installer or in portable mode.
Step A.
Download the appropriate .srt file for your movie. I prefer Subscene - Passionate about good subtitles
Step B.
- Start 3DSubtitler.exe.
- Browse to the .SRT file. The output file is usually in the same directory as the .srt file. Specify the path to BDSup2Sub.jar.
- Choose the font and font size. I use the default Arial Narrow and a size of 25. Bigger font size should be avoided as they can cause eye irritation.
- Select the 3D type.
- Select subtitle language.
- Set forced status to 'Not forced' otherwise you won't able to disable subtitle during playback.
- Choose font color.
- Select output format to Blu-Ray sup and size to 1080p or 720p depending on your TV screen.
- You can save your preferences by clicking 'Save Settings' for future use.
- Press the 'Check Input' button to view the subtitle. Remember, the image of 'cars' is indicative only.
- Press the 'Convert' button to create the .SUP subtitle.
Step C.
Start MKVToolnix (mmg.exe if you are using portable mode) and drag and drop the movie file. You can use MP4 and MKV files. Drag drop the .SUP file and it will appear as S_HDMV/PGS track. Set the language to 'eng' and forced flag to 'No'. Press 'Start Muxing' and after a few minutes you will get your movie embedded with 3D subtitle.
Step D.
SUP is the subtitle format used by Blu-Ray disks and not all players support embedded SUP subtitle. This is where XBMC shines. Remove the .srt file as by default XBMC will use the srt file instead of the embedded subtitle. Play the movie and you can enable or disable the subtitle by pressing 'T'.
Normal subtitle:
3D subtitle:
