Hi guys,
As the bug to try something new has bit me again (not for discontent - but rather for 'why not'); I have booked myself a Apollon Audio amp; that I should have by May if nothing changes as far as COVID is concerned and AL6000a is on the way out. Now considering I want to keep BlueSound Node 2i as my source/preamp (till I can collect enough to buy the HiFi Rose Streamers
) I am looking for a DAC to neutralise the DAC in the NODE 2i. Balanced output will be a plus as Apollon has Balanced In.
The requirements are -
1 - Budget upto 1L - Hard Stop - would prefer something cheaper.
2 - Should be a neutral/un-colored sounding or should be able to clean up what comes out of the Node 2i. I am fine with Neutral-ish sounding things, do not like bright sound at all and not a big fan of very warm sound. So something that is closer to neutral.
***I have been out of the desktop DAC game for a while - so absolutely unaware of what is great today.
Please help!
If you value convenience and features over everything else, the RME ADI-2 is hard to beat (
it reminds me of the discussion on the hifirose in the other thread). Even though it ever so slightly exceeds the defined budget, Consider that maverick flew below (
or above in this case) the hard deck when it was necessary.
Also, if you are interested in headphones/earphones, the RME's headphone amp section is pretty darn competent, especially in view of the available customisations such as cross feed, stereo width etc.
Consider its full list of features to gauge whether its the right DAC for you.
Some of the features that i found invaluable are:
1. Auto loading of loudness when the volume falls below a User definable volume (loudness curve i.e. q factor and the trigger frequency for bass and treble is also fully customizable)
2. Control of bass, treble, (including loading of EQ), and Channel Balance available on the remote. Plus, the remote keys can be fully remapped to any function.
3. Auto switching of input/output upon detection
4. 5 band PEQ (it is a revelation! hugely customisable for every single frequency between 20hz to 20,000 hz. Fixed my HE400i which had a weak bottom end. Also invaluable for adjusting frequency response to neutralise the effect of the room on my stereo setup)
5. LCD screen with realtime Visualizer and Horizontal Meters Displaying Pre/Post FX information (while the visualizer in itself makes it wirth getting the device, the horizontal meters are also extremely helpful to detect if the output signal is clipping, hence resulting in compressed dynamics).
6. Weighted reference volume levels at +6db steps (
the DAC makes a barely audible but oddly satisfying click when these setps are reached) to ensure that dynamics do not get compressed while modulating volume.
7. Separate outputs for 6.3mm and 3.5mm headphones(which is a low powered output).
Plus it meets your criteria of an extremely neutral and uncoloured DAC.
