Thanks again for your response !!
--> Budget : 45k ~ 60K (Started with 15k... but after going through various options, I guess I would bee fool to have a budget below 45~50K to have the complete HT system setup but also like to have a ceiling of 60K). It will be a one time investment for me. Not sure when will I be able to upgrade the setup.
--> Taste of music : All genre of music except hard rock (Rock, Blues, Mozart, Beethoven, Rabindra sangeet to Rap (fan of Eminem), Old Hindi melodies etc
--> Room size: ~ 15' X 20' Hall.
--> Movies : Music proportion: 30:70
On my second visit to the store....I've also liked NS-F8900
Hence the current config stands as
RX-V471 - Amplifiers (27k)
NS-F8900 - Floor standing speakers (19k)
NS-P8900 - Center/Surround (5k)(Not very convinced though with the audition. i would prefer clear and crisp vocal )
YST-SW215 - Subwoofer (12K) (Thinking of Polkaudio... perhaps)
Does the quotes mentioned seem fine or slightly on the higher side.
Is NS C444 a package of center and 2 rear surround or jsut center?. From model no. it seems to be just the center.
So now I'm confused about the center&surround and the Sub.
Though I'm not sure where can I audition Polk, Wharfedale or any of the other brands that you've mentioned in Bangalore.
Also, I was wodering if I plan to buy different speaker of different brand, I may end up paying higher as compared to buying of a single brand. Hence, was thinking of only buying the sub from eslewhereWhat would you Suggest?
AVR & FS - Yamaha
Center/rear- Yamaha or do you suggest a different brand since you personally do not like Yamaha Centers?
Sub - May be Yamaha, Polk or Wharfdale
Thanks in advance for your time spent in explaining me
