liverpool_for_life
The thread detailing my HT setup is here. Room dimensions/description are in the first post of that thread.
For a variety of reasons (including space, WAF, little ones running around etc.), I settled on the Paradigm Soundscape, a 5.1 sound bar.
My review of the sound bar is here.
As I said in the review, I don't believe I am getting the best out of the Soundscape and want to work on room correction to improve the SQ.
I am facing the following issues:
a. Lack of dialogue intelligibility in Movie mode (I specifically chose the Soundscape since it comes with separate drivers for each of the 3 front channels, so I know the room is the issue here)
b. Boomy bass/sound when the loudness option is turned on
c. Lack of stereo imaging ( I am not expecting a whole lot here, but some would be nice)
I have had a couple of folks visit my home to see what suggestions they might have.
The person from Anutone was patient and spent quite a bit of time. He was however reluctant to suggest anything other than a full-blown treatment covering 70% of the surface area, including the ceiling. Unfortunately, that puts the cost of the treatment way above my budget. I said I'd be ok with doing something within my budget and asked him to recommend first steps, but I haven't heard (and I suspect I won't).
I also had a visit from folks at Acoustics India (offices in T. Nagar). Surprisingly, their recommendation was foam in the corner (wall behind LP and wall to left of LP) and a 4ft by 4 ft rug in front of the LP. I was told that would make a dramatic difference to SQ and that was all I needed. Unfortunately, foam blocks in the corner of the room right up all the way to the ceiling doesn't pass the WAF test.
After a little bit of pushing (from my side!), I've been offered the choice of a 2 ft by 2ft synth absorption panel covered with fabric (2 in thick). The missus has seen the panels and is fine with them.
Suggestion from Acoustics India is 4 panels on the wall behind me and 2 on the left side wall. Nothing for the rest. Each panel will cost Rs. 2,000, inclusive of installation. Checking around, I realise this is steep.
So, I wanted to see if anyone has used their panels and what their thoughts were. Even if you haven't, what are your thoughts on the proposed suggestions for treatment. Can I get away with less? Do I need to do more?
Thanks in advance for all your help!
