Activate PBS on Roku
pbskidsorg
Florida
  • On the Roku home page go to the search bar
  • Now, type PBS from your remote
  • If you click on the search tab the virtual keyboard will open
  • You would see the Add channel overlay
  • When once you click that, a code will display on the TV connected to Roku
  • Take a note of this code
  • Then, launch a browser from your smartphone or your personal computer
  • Type pbs.org/activate in the web address bar and hit enter
  • pbs.org/activate will open and you should enter the activation code you noted down
  • After keying the code hit submit
  • Eventually, you can watch the PBS channel after 24 hours
