Kvandhi Watts and price have no correlation. A lot goes into making an amplifier than just wattage. Rotel also has a higher brand value vs Marantz/Yamaha/Denon?Onkyo. One of the characteristics of amplifier is the sound signature that it has and how well that sound signature works with any given speakers.
You may have seen the word "Synergy" used a lot in audio forums. So if a particular speaker is driven by say marantz, it might have different characteristics in the sound than Rotel. The differences can be minute to obvious depending on the combo in play. Which is why different amplifiers are recommended for different speakers. To get the best out of any system this combination has to work at optimum, hence you may see people changing DAC's, Source, Speaker cables/Inter connects or change tubes if using a tube buffer or tube preamp. For some it becomes a journey of a lifetime, (isn't that what hobbies are all about?).
In the end, forums like this can give you great ideas on how to better your existing system, let's you see what other nuts are up to with their gears, and the pursuit of happiness at can be derived under any given budget.
Personally, I am at a point where i am perfectly happy with my system and what it does for the type of music i listen to. But i have my eyes and ears open to see what tiny changes i can possible make to refine it. It's like cooking your favorite dish with making minor changes to the ingredients and see what tastes better,and keep refining it.
Hope that helps.
Hope that helps.
