surfatwork
Likely. The sparky is at 50% discount (just $17.50)I feel a new usbridge will be launched in very near future
ALLO being a digital transport, wondering if LPS will bring any major benefit.
Thanks for the link though.
I am also wondering how long a high capacity battery bank will last with the ALLO
The essential difference between the USBridge and digione is that the boards can be powered individually. You can go with a low noise SMPS or even better a LPS or a battery bank with the USBridge board and the ALLo wall wart for the Sparky board.digione signature
Also what is better to use, Allo sparky or RPI.
The way sparky is made it's more suited for audio
But the digione board won't run with sparky and the USBridge won't work with RPI
The big problem I had was in making it read my almost 2TB of music data. I found its library implementation shoddy.
it never updated.
For USB, yes, that is why ALLO developed Sparky with the USBridge.So I think as far as SBC is concerned the RPI or sparky does not make huge difference as far as an add-on card is used
Both must sound similar as the approach with both is the same, one being USB transport and the other with coaxial output.This is one bad thing I must admit, I did however compare USB Bridge (lent from a FM) with Digione (not signature) in my setup and almost sounded identical except that the female vocal was getting some undue smoothening in USBBridge
I believe the digione signature sounds closer to the USBridge.
Currently the DIY one. Will run comparisons sometime next weekSo which LPS do you use now?
Shanti or the one made by you ?
Please post your comparisons with USBridge (later).I just placed an order for the USBridge Sig.
I expect USB Signature to be equivalent to Digione Signature in term of design.@Kannan
So currently I use the Pi3 powered by a very good LPSU via its USB out to the Amanero I2S (USB powered) to my Soekris R2R DAC. I am using the Volumio OS and sometimes mOode OS.
Now looking at your new setup, I am thinking how much of an improvement does pairing a Digione Signature over my Pi3 and taking out the Coaxial over to the Soekris compared to the replacing my Pi3 with USBSignture and taking the USB out to the Amanero I2S (USB powered) to the Soekris?
