Alternate remote control
  • Thread starter Thread starter Deleted member 38504
  • Start date Start date
D
Guest
Hi guys,
I have a phillips HTS 4750.
Recently my remote is not working (yes i changed the batteries) hehe :) and i basically cant see movies through my usb cause the usb button is only on the remote.
Is there a universal remote i can use to make this work?
Everything else in on the player itself except for selection of the usb.
Thanks guys!
thank u so much but i still cant understand which one will be a match for the HTS4750...believe me i ve been trying to get some info on the net but keep hitting a blank wall...thanks...
Why don't you simply buy a replacement remote control? It will be a much cheaper option. There are two shops in ghatkopar who sell replacement remote for all and sundry brands, I had got my replacement remote control for my samsung LCD from there, works like a charm...I am sure there will other shops like this elsewhere in Mumbai.
The den for all this is of course lamington road, there are a couple of shops which just sell remote controls nothing else, you can try there also...
i tried in croma and they had no clue about anything! And i bought my HTS from croma!
There are so many options for the philips universal remote i just dont know which one will be a match :(
The croma guys are bunch of idiots, they usually are clueless about anything over the two line spiel they have been told to memorize. The shops I am talking about are essentially old world proprietor shops, they are pseudo wholesalers, and these replacement remotes are unbranded, but new. they cost between 100-400 rs., and they usually are flexible enough to sell it with the caveat that they will take it back if it doesn't work with your device
I have logitech harmony 525 and i am planning to sell it as i am not using it.. Let me know if it interests you..
