sixthsense
Was about to order the official onkyo wireless adapter for 2800/- and thought about reading the reviews first. So went onto amazon.com and the reviews were mixed and issues ranging from signal dropping to range to not working at all.
Came across a review which had an alternate suggestion of using another adapter having the same chipset as onkyo 'TP-Link TL-WN722N 150Mbps High Gain Wireless USB Lan Adapter' .
So ordered it from eBay.in for just 800/- rs and got it today. Within 5 minutes configured it with my wireless router with wep and got it up and running. Internet radio working fine. Now just need to test the DLNA function tomorow.
So don't waste your money on the expensive onkyo adapter and just order this one off eBay. It also come with a USB extension cable so that you can hide the adapter behind the receiver or slide it under it as I did.
Hope this helps onkyo users.
