Amp required for PC
cheakincheat
delhi
I m using Logitech x540 5.1 with my pc.
the problem i m facing is that when volume is in range of 50--60% the base is fine but when i turn it above 60% there is a lack of base.
The solution i thought of is to attach an emp to my pc and an additional subwoofer. i need some help in finding out the amp for this setup
Budget --10,000--12,000(Amp + sub)(if there is smthing better beyond this budget i cn streach my pockets a little.)
plz suggest.......(even if you hv some better solution to my proble too)
:rolleyes::rolleyes::rolleyes::rolleyes:
A good Amp + Sub will cross 15,000/- You will need an Amp with Pre-out to connect to the Sub.
Best will be bookshelves + Sub + Stereo Amp.
Francis
In that range Norge amp is your best bet but you need to find out which model has pre-out
Sent from my iPod touch
