AMP to match WHARFDALE EVO 4.2
Sorry my mistake. I thought you had KEF R3. Also didn't knew AKSA needed preamp. As for carrying an amp to rpggoa's place I think he/she is planning to purchase wharfedale evo.
regards
Planning to buy Wharfdale Evo 4.2 Bookshelf speakers. please suggest a suitable budget amp to drive these speakers.
Ah.. Then check if an audition is available at a dealer. The dealer would have paired it with some suitable amp.
Should give you an idea.
Send a PM to Evo 4.2 owners on the forum too.
regards
This AKSA build is just a poweramp, though the designer (Hugh Dean) has helped many folks to add a passive preamp or volume control.
The R3s are a tad better than what I have in the bass department. R3 definitely has better looks (SQ = sexiness quotient)
Raghu
