hi,
I need an urgent advice. I have a suzuki swift and have the following car audio already installed:
1) Head Unit- Sony Double din
2) Front speakers- JBL coax, 6 inch, 50 w rms speakers
3) Rear speakers- Pioneer coax, 5 way, oval, 100w rms speakers
I am looking at enhancing the sound. I am looking at clear sound with good bass.
I am looking at an amp wit a sub. following are the options, which one do you think will be advisable:
1) buy a 2 channel amp and connect to sub
2) buy a 4 channel amp and power the sub and front speakers. the rear speakers will be powered by the head unit
3) buy a 4 channel amp and power the sub and rear speakers. the front speakers will be powered by the head unit.
I have a limited budget and hence the above options only pls. I am looking at quality sound , good bass. i listen to primarily rock music.
