Kevian
Guys,
I have an Onkyo 606 for HT job and Rotel RA06 for stereo listening. My house's renovation will be over in a couple of weeks or so. So, my equipment will be moving to "Music Hall" as I call it. For now, I'll be using Mordaunt Short Carnival range for fronts and center while DefTech Promon 800's will serve as L&R surrounds. This'll make a 5.0 setup.
My question:
As I have 2 amps and 1 pair of front speakers(which I'll upgrade in near future), do you audiophile guys think a product like this will be good enough in switching between amps? Will it be a compromise on music listening once I upgrade to better fronts? Do you have a better recommendation as my front and center speakers upgrade could be to Dali/B&W/Paradigm?
Russound AB-2.2
Tabletop A/B selector
TIA & Cheers!!
Kevian
My question:
Russound AB-2.2
	Features
Overview: The Russound AB-2.2 is a dual-source selector switch that allows a single pair of speakers to be driven by either of two amplifiers, or to allow a single amplifier to drive either of two pairs of speakers. It is a tabletop unit with a push-on, push-off button to switch between the dual amplifier or speaker pairs.
Connections: The AB-2.2 has three removable, color-coded, screwless snap connectors which accept up to 14-gauge wire. These connectors have wire locking levers which snap the speaker wire into place.
Specifications: The AB-2.2 is designed for use with amplifiers with a power output of up to 150 watts RMS per channel.
TIA & Cheers!!
Kevian
