Amusing Audio!
If you are board of listening to your records or you are a DJ and looking for some unique sounds, play your records in reverse!
Resonant Frequency Tuners - Tuning Dots
"Marigo's VTS Tuning Dots have been one of the most effective and dramatic steps I have taken to improve my system's performance. The improvements were not subtle. They brought great transparency without losing musicality. Clarity, dynamics, inner detail, midrange bloom, bass slam and articulation have such an improved sense of openness that they represent a major paradigm shift in resonance control." - David Clark, Positive Feedback, excerpt from online review, issue one
One of the power cord user review on ebay page of this "Orca Egg" seller. He was "paralysed" by hearing this powercord in his system.
Special edition power cable with European connectors! This is the only EU power cable built which has the Supernova Crystal Fromula inside. It's 4 meters long which gives greater cleaning power than the 2m Supernova we sold in the past.
The connectors are genuine Furutech FI-11 (R) which are Rhodium plated. They were in used condition before building this cable, so they have a lot of scratches on them, but this doesn't affect the sound.
The best placement for this cable is for source components like DACs, CD players or computer transports. It's recommended to use the longest cable for the source, and the shortest for the amplifier.
Subjective impressions
Compared to the standard Supernova power cables, this EU version has a more liquid smooth and natural sound with greater soundstage size that expands in all directions. It will take you into a state of trance where you just melt away into the music.
Specifications
Crystal Formula: Supernova (2019)
Wiring: 70 microns extruded pure silver surface 7N OFC surface, 16awg solid core
Insulation material: FEP with threads around conductors (air dielectric)
Speed: 91% the speed of light
Connectors: Genuine Furutech FI-11 (R). European Schuko plug
Tube ending seal: White wood + Black Quartz Crystals
Sleeving: No
Grounding: No
Shielding: No
Thickness of outer tubing: 16mm
Length: 400cm
Release date: Year 2019
The Supernova 4m is the best European power cable ever built which is at least 100 times better than the first Hyperspace version in the review below!
**********REVIEW (first Hyperspace version, year 2011)**********
I just got your 4m powercord today. As I mentioned before, my system consists of an MBL 1611 and 1621 DAC/Transport, Shindo Monbrison Pre-amp, modified EAR 890 Amp and Von Schweikert VR4 gen iii HSE speakers. The other Hyperspace cord that I got last month is on loan to a friend, so the new one was the only Hyperspace cord in the whole system. The rest of the powercords and interconnects are currently Audience AU24 e's.
I hooked the cord up to my MBL dac and was stunned motionless.
I became paralyzed, sort of a dream paralysis perhaps, unable to move even after the CD ended. The sound was so expansive, there were no walls, every instrument and voice could be clearly followed while at the same time the entire blend of sound was unified into a single flow of music. Even at 90db + volume with a rock beat, the music was so relaxing that I was immediately placed into a trance, unaware of my body or the room around me, just pulled along by the music.
I know this sounds gushing and overstated, but what it comes down is that I cannot f***ing believe what this powercord does. It makes no rational sense that a single cord could transform the sound in this manner. It is a quantum leap past the limits of what I thought was possible; through the veil and over into another realm, another dimension, where music and sound are experienced more deeply, beyond ordinary perception.
In the last year, I have used Virtual Dynamic Genesis, ASI Livelines, and Audience AU24 e powercords in my system. Those are all excellent powercords. But there is literally no comparison: the Hyperspace cord exists in a different realm. The difference is not the slightest bit subtle. It takes no effort to hear what the Hyperspace does. In fact, it is not possible to ignore the effect, not possible to ignore the allure, charm, and breath of the music. It isn't a matter of "rediscovering my CD collection." It is a matter of hearing music for the first time. I don't know what I was listening to on my CD's before, but is was skeletal and barren compared to what is emerging and flowing into the room now. I cannot fathom what it will do to add more of your cords, but I am hooked. I feel I could be happy with just this one cord, but I feel compelled to explore deeper into this sort of space. I have been searching for this sort of experience from my stereo for the last 25 years.... who would have guessed that a powercord would be the missing link.
I am aware that my speakers are a relative weak point in my current system. Prior to coming across the Hyperspace cord, I had been itching to upgrade the speakers. While I know that I will probably eventually do so, I no longer feel any urgency. It is amazing what these speakers, which are 1/10th the the cost of the MBL source components, are able to do when given a pure and clear signal. And it is amazing what this powercord can contribute to the performance of DAC that retails for more than $25k.
I have bought so many powercords and interconnects based on "critical audition" where I had to listen very carefully to hear what it was doing. Prior to this, every system upgrade, including major component upgrades, have been slight to moderate changes along a continuum. This is a quantum jump of a different sort. Instead of trudging along a continuum of gradual improvements in resolution and musicality, the effect of the Hyperspace is exactly as the name implies - it transports the experience of sound to another realm, a place that is not bound by the limits of three or even four dimensions. I do not know how to describe it more clearly as I have no prior experience to compare it to.
For example, as much as I love my Shindo Monbrison Pre-amp, the effect of the hyperspace hands down trumps the benefit of the Shindo. If I had to choose, I would trade my Monbrison for a Hyperspace cord without a moments hesitation. The same goes for my MBL DAC and transport. The Hyperspace is not only "that good", it is beyond comparison.
The effect of the hyperspace is immediate - it literally grabs you by the balls and hold you still until the music is over. Actually, even beyond the end of the music as I find myself continuing in an altered state of mind/body for a while afterwards. I don't know yet how long the effect lasts as my girlfriend, who had been calling me for dinner for the over an hour, had to come grab my arm and pull me out of the chair.
No one is going to believe any of this unless they take the leap and try it. It is unlike any other upgrade I have ever done -- (I can't wait to take it over to my friend's house and hook it up to his system Berning Qaudature Z amps, Lomichay Kandinsky Speakers ($75k speakers)) - Kot Biehl (USA)
Passive Multi-Vocal Resonator​
"The PMR produces only harmonics that are perceived by the human ear as pleasant and harmonious. The sounds of music are heard as natural. These "right" overtones are the result of decades of sound research. And by the way... bell bronze is the only material that can reproduce all overtones of the musical scale. This know-how is now being implemented. By overlaying the music with a full scale of multi-vocal overtones, more detailed sound is produced. The music gets more momentum and energy, the presentation of the instruments is more realistic, more solid and three-dimensional. The spatial imaging is increased in all directions. The result is again a natural and authentic sound experience with beautiful sounds.”
Machina Dynamica's Brilliant Pebbles
Brilliant Pebbles is a unique and comprehensive system for tuning the room and audio system based on the special physical properties of highly symmetrical crystal structures. Brilliant Pebbles addresses specific resonance control and RFI/EMI absorption problems associated with audio electronics.
They have a White paper called POWER TO THE PEBBLE!
There was a similar proposal to us to improve the harmonics in power networks sometime back - by sticking something on cables. We asked for real life measurements and the promoter of that product in UAE went back never to come back!!!
You're just a measurement junkie like Amir of ASR. Everyone knows that measurements mean nothing and the only measurement of any value is an ECG. Because music should touch the "heart". :p
Touch the Heart, Caress the Jewels, and wipe out the bank balance, all for that “airiness” one feels around the ears!
Measurement is money for our sector - one would lose if there is error and the other gains. Supply to consumers could trip if the decimal in time measurement is not right or not set correct. Or bury money (read cables) unnecessarily if readings are inaccurate.
For audio I am still to expand my "measuring-philia". After all its only a hobby and can burn my pocket :D
With those wonder tapes that inventor proposed us he'd have wiped out millions of $ in one go, these wonder pebbles guys wipe out the same money trapping a few thousands of gullible;);)
Disclaimer: for all my poor jokes et al, I'm fascinated and also enamored by the seeming "voodoo" in audio. I'm also a believer in the unknown and in fact have even implemented some of the weird stuff out there in our hobby. There's always a struggle between my 2 lobes because the gains (when they are present in 0.1% cases) have been minor and totally not worth it in my opinion. But i would also like to think that I have an open mind towards this stuff and most importantly, I am very cheap and don't spend much money towards this and only implement such stuff when I can DIY it.
