Amusing Audio!
It will work fine only when the Solar Coronal Hole is pointed away from the room.
If pointing to the room, it makes the sound too bright! :p
We must invent a compass to detect Solar Coronal Hole direction, find it's coordinates in 3D and time and mount the room on a gyro like thingy to move it away from the Hole and on all 3 axes at the proper time. Proposing to Shark Tank
Majestic system but only amusing part is the guy who invested 20 years to build this priceless system doesn't believe in cable effects !!
He says the Western Electrics are 13' tall at the 8:15 mark. How? Even if you consider the person in video 6' tall, the speakers appear to be about 9.5' tall. The room itself doesn't seem to be 13' high!
Carbon Tuning Discs - Colourful stickers to lighten your wallet.
It is best to stick them on your forehead and think of the awful decisions you've been making!
Carbon Tuning Discs enable a large, even flamboyant sound stage that is layered, holographic, and real. Tonally Purple is a clarifying force that fleshes out inner detail and linearity, so it’s perfect for hearing your music with clarity and holographic realism. In addition, they improve low-frequency weight and attack with proper placement.
Or to prevent those kind of "negative" thoughts entering the brain - just like the kumkum / chandan tilak ;)
BTW how do you land at such amusing stuff?
Its Obvious . Still searching for THAT specific missing note. :D
.. the search encompasses audio , non audio domain too.
Demagnetize LP and CD - From Fraudulent Furutech
6moons hits it out of the park with "It seemed as if analog was even more analog"
What does this amazing product do? It demagnetizes your vinyl, because your vinyl contains carbon and carbon attracts a magnetic charge. That magnetic charge apparently adds "a layer of grit, glare, and haze" that the LP Demagnetizer magically removes. Of course, once your LP has been run through the Demagnetizer, it will reveal the usual "smoother treble and increased dimensionality," according to The Absolute Sound.
