After replacing the hard drive with a SSD and removing the optical drive and all the case fans, the SMPS fan became the noisiest part in the PC. When I started looking for a SMPS without a fan, I thought maybe I could put a linear power supply instead. Not only will it have no acoustic noise, it would solve the electric noise problem too.
It was while researching linear power supplies that I ran into picoPSU. A really tiny PSU that runs off a 12 volt power supply. Even though it is switched, the +12 volt bus carries the voltage that we feed into it. It was a quick way to get rid of the SMPS fan and the bulky SMPS itself.
The pictures below show the makeshift system I managed to get running today. The power is coming from a 3 channel lab power supply. Eventually, I intend to put a transformer/rectifier based power supply inside the case. Will update this thread as the build progresses.
The mandatory pics:
Since I intend to move to a USB DAC, I have temporarily abandoned my plans to build a fully linear ATX power supply. However, if sufficient number of folks (hopefully some from Bangalore ) are interested, we could start a community project. Would love to participate.
The mandatory pics:
