I need a 4K player .Hi
I am using ASUS O'Play mini in my HT setup. It plays , and has audio passthrough function, for 1080p videos with Dolby Atmos, Dolby TrueHD and DTS HD from external HDD.
My 2 cents
You have to search in OLX as ASUS has stopped selling this media player.Will check it.
So the only player which mostly suits ur need is shield.I need a 4K player .
It will support i have used. Just check on you tube before buyingmi box dosent support dolby atmos
Hi,MECOOL KM2 Amlogic S905X2 Youtube Netflix 4K DDR4 2GB RAM 8GB eMMC ROM bluetooth 4.2 5G Wifi Android 10.0 4K HDR10+ TV Box HDMI 2.1 H.265 VP9 Decoder Dolby Widevine L1 OTT Box Google Certified. This is the best amongst all. I have done immense research on android tv boxes.
This one is not available now ODROID C2 is available. Will RPI4 be better?When installed with coreELEC, this is quite capable..
Buy Odroid-N2+ Online in India at Fab.to.Lab
ODROID-N2+ is a new generation single board computer that is more powerful, more stable, and faster. The main CPU is based on big.Little architecture which integrates a quad-core ARM Cortex-A73 CPU cluster and a dual core Cortex-A53 cluster with a new genwww.fabtolab.com
RPi4 does not support Dolby trueHD.This one is not available now ODROID C2 is available. Will RPI4 be better?
N2+ seems to be available..This one is not available now ODROID C2 is available. Will RPI4 be better?
Great. So where can I get all the information for setting it up.N2+ seems to be available..
I am using N2 for more than 2 years, playing movies from NAS as well as directly attached 6tb drive without any issues.
You may like to read and study more, refer below for download and installation guide.Great. So where can I get all the information for setting it up.
It is easy , you can buy any latest amlogic android box and install coreelec on sd card , I am using tox1 from 2 years.Great. So where can I get all the information for setting it up.
Ok. So now i have these optionsYou may like to read and study more, refer below for download and installation guide.
You can not find many options in india. Firetv stick is a option but you need a media server like plex to work or you can connect the storage device to usb port using a otg cable and use vlc for playing local media files. But the problem is with firetv stick is it does not support dts passthrough.Dear FMs,
I am looking at this Android Box for playing 4K True HD ATMOS movies (50-80GB) from external HDD. On paper this box looks competent.
Android Box. (HK1 RBOX from Bangood)
Should I go for it ? Will i face any issues with it? My AVR is Denon x2400 connected to Sony X9000H TV.
Is Bangood reliable?
Thanks in advance.
His budget is within 7k.Shield TV pro is the best box hands down.
