Android tv box or media player in india
Bhushandn
Pune
I am looking for best media streaming player/Android tv box suitable for yamaha RX V479
Budget - 10 to 15k
Pls suggest...
If you need a android box than look for Nvidia Shield but you will have to get it imported from USA, there may be few selling locally though.
if you just need for streaming purpose than better to buy Firestick 4k from Amazon, much cheaper and does better work than most Android boxes.
Yeah..nvidia shield is best but not getting easily.
I wanted to use it for streaming as well for movies through USB and should play 5.1 with TrueHD.
I am using Sony BDP S-1500 but not getting expected output. So going to sell this and buy a media player
Don't need 4k right now but want to make it future proof. Mainly for movies through USB,HDD & from mobile
Most of the android boxes won't future proof for 4k playback on usb/hdd.
For this, nvidia shield is best bet but is pricey option.
Apple TV with infuse is also an option, but has some limitations on audio support.
I have a 2017 Shield purchased from Amazon.com in July 2018, I might let it go (if price is right) to buy 2019 Nvidia Tv for its AI Upscaling, heard good things about it.
Himedia 900B is1080P, I am looking for 4K
I am another one as well HiMedia H8 Plus, it is better then Himedia 900B and support 4K too but it doesnt has HDD enclosure like 900B has, you need to attached HDD via USB
check at your end and let me know if interested over pm.
