elangoas
@elangoas, Can you confirm if your android box passes through lossless audio formats to the receiver out of the box? If not then installing Kodi will enable this functionality?
Yes.. It is able to passthrough (Atmos / Dts X) thru Kodi application from BR Rips.. Most Android TV box come with Kodi pre-installed.. (or) you download one from playstore..
I actually have an Amazon Fire TV Stick 2 which I want to use with my projector to stream movies. I am wondering if this stick can somehow be configured to pass through lossless audio formats from a hard disk? Is there any adapter which will allow an external HDD to be connected to the Fire TV Stick?
Think the Fire stick TV has only HDMI & a Micro USB port to power it up.. If there was atleast one USB port, then you can connect a USB hub and then connect other devices..
If this is not possible then I would have to go for a cheap android box which can pass through Dolby TrueHD and DTS-HD MA from a HDD. Not looking at spending too much on a Shield.
Getting nvidia shield just to passthrough audio is an overkill.. Any ATB for <5K should be able to do it straight forward..
Any confirmed box out there which can do this within 5k?
Think the X96 Mini with decent hardware for 3.2K INR can do it.. Please check youtube videos of the product to get rough impressions..
