Amitkg
I sent a mail to MMX, regarding extended warranty, but never got any response from them. What if it conks out after a year? Even 35K is not small amount
I sent a mail to MMX, regarding extended warranty, but never got any response from them. What if it conks out after a year? Even 35K is not small amount![]()
I can pick this up as I picked this 50 incher a month ago and simply loving it:
1) SD content is alright and not bad at all. Some channels seem to be very good and some a bit pixelated. HD content is simply a beauty.
2) ... extended warranty on this TV - I don't think this option is available.
I called up Micromax LED support and they confirmed that there is no option for extended warranty.
That most probably, speaks volumes about the durability of the producthyeah:
hyeah:
hyeah:
FLASH FLASH
Lowest price i have seen of this TV. 28990 (under exchange of working LCD tv) . If you have HDFC credit card, another 2500 off via EMI. So the effective price will be 26500. Its valid for the next 20 hours. .so hurry up folks..
- Have you demoed/auditioned this TV anywhere in Hyderabad, or ordered it without taking a look at the product in real?
- How does the SD content look? I usually watch SD TV from the cable set-top box, connected to the TV with a composite video cable? This is usage #1 for me.
- I noticed in some reviews that subtitles look very very tiny. Do you face such problem with videos played off USB sticks/hard drives? Not that this is a deal breaker for me.
- How about the viewing angles? Does the picture get washed out when view off-axis? How about the blacks, the contrast, etc.,?
I just ordered this TV from Flipkart.
After warranty its just luck, but at this price, its worth the Risk.
I could only see one TV that too 32 inches at a Pai International. But i didnt like it bcos there was no content to play, some stupid mobile quality vidoes being played. So i relied on the various reviews on the net and purchased the tv.
SD content looks really good & HD blows your mind away. In SD some channels look better than others. But overall its good. I use a Tata Sky HD box and an HDMI cable to connect to TV.
Viewing angles are pretty good. I have seen the TV from almost all coreners of my room and didnt notice any wash out of images. Intitally i was using the standard settings, and didnt what i saw, then tweaked the settings and now it pretty good. The blacks are awesome , so is the contrast. YOu need to adjust the best settings depending on the over lighting of the room , distance from TV etc.
Did you get a chance to have a real look at the TV, like in an electronics store in Hyderabad. If yes, please let me know the location.
Have you based your decision only on online reviews?
