Anyone using Pioneer HTP-RS42 ?
I have auditioned 32 some time back. Overall good but center could have been better. I feel that the sub-woofer was the best out of all HTIB's available in 50k bracket.
The 42 series seem to come with two options of speaker set
1. RS33TB - downside is that it has got a passive radiator
2. RS77TB - good sensitivity
However, it looks like 42 does not support connecting Ipod thru USB, for which you will have to upgrade to 52 series
See if you can audition 42 with RS77TB if Ipod connectivity does not matter.
Okay good.
I will take a demo of that one as well.
I just feel like, I might end up spending too much assembling a HiFi system and then wont be getting time to enjoy it.
So, better to get a complete HTiB and stay happy with that. :cool:
@soamz
hi.....it is very loud ...more than enough to blow out my neighbours...
as it has got active sub, response to low freq is dammn good...
i pod connectivity and frnt usb port does not matter fr me...as u have to buy dvd or blue ray player fr ur HT, which comes with all those features...
the only downside i felt abt this system that it has got only 2 hdmi inputs, but fr my need they r sufficient, and u can always add a hdmi switcher to increase no of ports if u want....
Ok, how clean is the sound ?
And how big is the packaging ?
Can I bring that in the aeroplane as baggage ?
The product page says,
REAR TERMINALS
HDMI 4 in/1 out
AV (Composite) 2 in
Audio 2 in/Rec 1 out
Digital Coaxial 1 in (assignable)
Digital Optical 1 in (assignable)
Monitor Composite 1 out
Preout 1 SB out, 1 SW out
Speaker 5ch out
@soamz
Hi, whats ur avr in the package? when i tested rs32 at reliance recently it had vsx-322-k VSX-322-K 5.1-channel HDMI 3D AV Receiver with ARC, Dolby TrueHD and DTS-HD Master Audio - Pioneer Amplifier, AV Receiver
where have you bought ? I have seen in reliance digital for 37K. Any better price for RS32
Today I checked with a Reliance Digitial store in Kolkata and the price is still Rs.37,000/-. They are offering a Samsung 3D blu ray player for additional Rs.3,000/- (as per their claim the price of the said blu ray is Rs.8,000/-)
Which blu ray player are they giving with this pack ? I guess they ll give Samsung 5500. Please find the below
Rs.6499 for a Samsung BD-E5500 Blu-ray Player | GROUPON.co.in
It feel, its worth the money but do u like the HT after demo ??? Bcoz i dint like personally. :sad:
I am not very sure about the model no. of the blu ray player. And regarding the HT demo, I found it better than Onkyo 3500 (but unfortunately I demoed the Onkyo with pirated dvds and mp3 in a not so good demo room unlike I demoed Pioneer with original bluray in a very good HT demo room).
No way man.. I had Onkyo HT 3500 fr more than a year... Even though Pioneer has towers , it can never compared with Onkyo quality.. I auditioned R32/42 many times but i don't like the quality and crisp at all.
I suggest Jamo S 426 package is better than R42. Anyways ur the listener and finally its ur call.. But keep it simple buddy, never go for attractive package unless u don't compromise anything :)
I have auditioned RS42 in chennai Reliance (Offer 30K - No free bees).
This is louder and the look is very nice. But unfortunatelly, IMO, It is not able to play well on mid range frequencies. Missing detailed music. Not able to produce sound field.
Dear Swamy, was it RS 32 or RS 42? Cuz I had checked here in Bangalore at many places, and minimum I got 30K for RS32 that too a display piece. Min for RS42, I am getting 40K here for a fresh one offcourse. Which Reliance digital did you go? Can you give me the contact? Thanks
I apologize, Its my mistake (Number confusion). It is RS-32 quoated for 30K in Ambattur-Branch, Chennai.
Shop for Pioneer HTP RS32 5 Channels 100W Home Theatre System with AV Receiver at Reliance Digital
Hi Swamy,
Are they still having this offer ? Do u think its gud to go with RS 32 or Onkyo/Denon/Yamaha
Please check with neary by Reliance digital. PM me, if you decided to buy this and need to check in Ambattur branch for the offer.
Personally, I don't like this. It is lack of creating sound field. (A 5.1 should create a sound field, Other wise no use of 6 channels).
Onkyo/Denon/Yamaha...planing to have to adution next month.
IMO, sound is individual tast, Go audtion multiple brands and select on your tast..!
Looks in your signature, you already having an Onkyo.!
