superczar
- Joined
- Feb 5, 2008
- Messages
- 836
- Points
- 93
Continuing on the theme of limiting corrections to 500 hz (or cutting at off at the room schroeder)
Here is what I ended up doing a few months ago.
www.hifivision.com
What I also did around then was to measure the post correction response independently - which I believe yould should also be able to do .
The curves here are full range but the final setup has the cutoff applied at 224hz.
If and when you get the time, it would be worthwhile to measure the bass response (via Audyssey in your case) with and without the new doohickey
Before Correction
Wishful thinking (projected post correction curve)
Actual independent measurement with Anthem
Audyssey MultEQ Editor and Stereo Playback (Plus Anthem Room Correction)
I recently swapped out a Marantz 6010 with a Denon x3500. TL;DR - If you have any Denon/ Marantz receiver that you may have purchased 2016/17 onwards, rush to App Store/ Play store to get this App without thinking twice If you want the gory detaills , read on-> Now my biggest problem with...
Before Correction
