Audio connection between DVD player and AVR
Hello,
I have a question in this regard which is to do with LFE. Well in DVD player which has a 7.1 output if we only connect the fronts as stereo output then should we get any LFE signals. I mean to say in case if we are using a floor stander with considerable bass is it needed to make the analogue connection for subwoofer as well for complete bass effect. In this context is it also fair to assume that when there is dedicated stereo output then the internal circuit is not filtering any of the LFE signals like it is doing in 7.1 output???
Thanks,
Mahiruha
Well DVD player will have option to switch off Sub output.(my Onida has that)
So if you connect frnts to flrstands,then turn off SW from DVDp setting,naturally LFE will go to frnts.:thumbsup:
