Audio Rack
Here is my audio rack, made by 18MM plywood and teak.
Sachin
I have a sheesham Rack (Very heavy) bought from fab india. Was thinking of buying a granite slab and installing isolation feet/pods and using it as a TT isolation plinth. Would it help? Any pointers
This is one of the high end tuner. I imported it from US.
Sachin
Must be 110 volts?
Must be readymade? I guess. Any pics possible? I can then check at local store.
thnx
Looks like made for hifi. Great you got it from fab.if you don't mind me asking the cost?
So bought it a few years ago (5) price then was 15k. Posting the old pic the new look was done around 2 weeks ago. Was thinking of replacing with something Modern looking but then decided to give it a makeover(all diy)
While making closed cabinets (instead of open racks) do ensure they won’t resonate. Provide adequate vents for aeration as well as sufficient weight top to dampen vibrations.
