Hi Guys,
I am building a new house, and have a duplex appartment for myself. I need advice for audio/video planning. 1 thing I am keen on is having speakers in all rooms, tv in a few bedrooms. Cost wise I would like to keep things to a minimum, but if required we can go higher.
I definitely want to be able to play music of the ipad/iphone and laptops wirelessly hence wifi connectivity of entire system is necessary.
The most important decision to make is if I should get a common multi room amp and all speakers connected to it. I dont like this since individual control is lost and longer wires definitely mean more errors/problems and downtimes.
Second option is individual amps connected via lan cables and onto a switch/ router. Have no idea how this would work but I have a feeling this would be better solution.
The layout of the duplex and requirements are as follows:-
Ground Floor:-
1. Drawing Room: thinking of a 5.1 speaker system, no tv planned as yet but maybe in future I might put it. 17x30 feet. need small speakers which blend in.
Dinning Area is a separate room attached to the drawing so I was thinking maybe get a 2 zone amp and use that to control both areas.Thinking of just 2 wall mount speakers here.(20x10ft approx)
Would like to keep both the areas combined in a range of 1Lac.
2. Infant Child Room:- No thought as to what to put, open to advice if to put or just get cabling done and keep it future ready.Room size- 12x15ft.
3. My bedroom:- Would put a smart tv(probably 50-55"), what audio system to go with. room size 17x14". thinking of a 5.1 setup again. Need small wall mount speakers since tight on space.Range 50-70k. Wife wants bose but I am not keen on lifestyle 520 kinda budget.
First Floor:-
1. My dads room who is very fond of music, has a pair of b&w bookshelfs which we will definitely use here with a new amp if needed. size 20x17ft.Range for amp 30-40k.
2. A tv room(65"tv to get) which will double as a guest room if needed. 5.1 for sure. 14x17".Range for 5.1 including amp 30-50k.
3. Another room where I put my old 32" samsung and active edifier studio monitors attached to wifi device/ receiver to bring it on to the network.(17x14ft). range 5k for wifi device.
4. A lobby area in the middle where I plan to put another 5.1. Reasonable one like onkyo. size 10x20ft. range 35k.
I know onkyo currently is not wifi enabled but I am hoping by the time I complete my house (8-12months away) they will be.
Currently conduting work is going on so want to get the speaker cables also put in now and hence need to figure which type of system and interconnectivity.
A great big thanks in advance.
Ground Floor:-
First Floor:-
