Vivek Batra
Hi FMs
I need your urgent help on deciding between the two DACs. I have no prior experience with any of the component. I am going to pair the dac with following
1. Luxman 590 AXII Integrated Amplifier
2. Klipsch Forte Speakers
It will be great help to me if you could compare the two DACs and is it worth staying with in the same brand (Luxman) for the dac as well? I do not see any advantage in Luxman over Audiolab. Almost same specs but the price difference is double.
For you convenience I have pulled down the specs for both the models below. Kindly suggest which one should be more suitable for the system overall.
Thanks a lot.
Thanks a lot.
