Vivek Batra
I am not against what Rikhav said that's totally sane advice.what rikhav means is that
a. first get the music going on your Luxman amp and Klipsch Fortes
b. Get them to sound correct with speaker positioning etc...
c. For this process you might not need an expensive dac
d. While you play music with the above 3 points in play - your mind will wander to what kind of sound you like in your room and WITH the amp and speakers
Then go fishing for the big one..
I guess thats what he is trying to say and his thoughts have some merit.
OTOH
if you find Luxman DA 250 too attractive - go for it !
I am quite sure a Luxman DAC wont be too bad at all
It just depends on the buyer and his way of thinking
There is no right or wrong here..
Just 2 different approaches.
Good luck and let us know what you went for !
regards
I have asked the dealer to confirm the availability of 250, if it's not available anymore I am with you guys then I have no hurry at all I can wait and save money for some time.
