Does any one know where graphic equalizers are available in Mumbai? I am looking for one desperately.
regards,
Raja
Hi again,
Am not being negative but please dont just buy unless 100 % sure. Generally these eqs are very poor in internal build quality. I know its only 5 K but believe me the internals are not worth even 2 K. Many years ago in college when money was really tight me and two friends bought a jetking kit from lamington road and made equalizers for our use as the then system (Sony orson) lacked everything and it sounded good and boosted the frequencies but with seperates today i would never use eqs.
Anyway thats only an opinion.
Regards.
Hi Anil
I think Dinyaar is right , unless you listen to very old music there is no need for an EQ, But if you still want one ,buy some imported second hand EQs
Yamaha has an Equalizer which is available for around 12k , kindly check that too.
dev.
chaudhary trading at lamington also import equis from taiwan - 10 + 10 band. price is again 5.5.k. same features as abv.
regards,
Raja
Can anybody provide the contact details of Narain Pro Audio?
