spirovious
Anyone mentioned it?Interesting - what is the price?
Sid
Sid
Using non-stacked multiple subs leads to phase cancellations
Even if they are all playing in phase!!
kooldeep, was awaiting an fr post ur visit.
do spare some time, if convenient.
some one mentioned earlier that it will be close to SVS-PB12
Why don't FM's who intend to buy such a sub contact Kanwarji directly, instead of asking others who themselves don't know the answer![]()
Do you expect placing the two subs in opposite direction to each other and still maintaining the phase..... ????
In that case we need to reverse the phase of one of the subs.
In non stacking mode in front firing, a lot depends on the room itself. Ripple effect is prominent.
If the subs have the same phase settings, and if they are facing each other, there would be a cancellation, I think.
Now lets come to the issue. The vibrating cones of the two subs facing each other receiving the same musical signal and operating in phase would produce the sound waves in phase but from opposing directions. When these meet in the air, they both would push against each other thereby weakening in the process. However they would not be cancelling out each other. That would happen only if the subs are playing 180 degrees out of phase.
Hope my point makes sense to you.
If two subwoofers are facing each other & firing at each other (S1----><----S2), and both have the same phase setting, aren't they effectively 180 degrees out of phase (= playing in opposing phase)?
Shouldn't we reverse the phase of one of the subwoofers (say keep one at 180 degrees & keep the other at 0 degrees), while keeping them facing each other, so that they are both in phase?
If the sound signal is reaching both the subwoofers at the same time and the phase settings on both the subs are similar and the drivers are firing at the same time, of course I would expect them to maintain phase. Why not?
How will the distance affect the phase of the sound wave?
As per my understanding, sound propagation itself is through ripple effect. What is the ripple effect you are referring to?
Yes Capt., it does. What I was confused about is this:
The ripple effect i am talking about is this: Think of throwing a single stone in the pond, the circular ripples will emerge moving outwards, now think of throwing 2 similar stones at same time, at certain point they tend to cancel the the ripple effect from each other, hence cancellation.
When the 2 waves of same phase collide from opposite direction, cancellation does happen which is evident from the fact that the SPL level at that point actually decreases, because energy of the waves get disperesed. I have experimented this a lot in real world, the decrease is sometimes as much as 6dB in open space
IMHO the term "cancellation" would be apt to describe the phenomenon of two sound waves,180 degrees out of phase, colliding with each other. That would result in annihilation of the sound itself, the way it gets done in 'Noise Cancellation Headphones"
Active/Electronic traps: I only know of one, the Bag End E-Trap System. This uses a dedicated subwoofer & electronics to pinpoint two desired modal resonances. This product actually comes with software to aid in the process. The system then emits a counter wave to diminish these resonancesreally does work and takes a lot less space than many of the above. Oh, and this is not an additional subwoofer for your system, it is just addressing modal resonance.
Best example of cancellation would be two subs placed next to each other (side by side) and driven out of phase. This will result in almost greater than 12dB of reduction in bass.
Next comes the scenario of two subs facing each other driven in same phase. Here the cancellation will occur but at much lesser extent, its more like dispersion of energy and filling the empty pockets. You will get 3-6dB decrease in SPL depending on the distance
