H htseeker New Member Joined Dec 2, 2010 Messages 45 Points 0 Location Bangalore Dec 17, 2012 #1 Hi..I'm setting up a HT and will be using it to primarily watch movies and only a little bit of music. I wanted to check if there are specific brands that are specially known to render a greater movie performance than others. Thanks.
Kittu New Member Joined Apr 5, 2010 Messages 5,349 Points 0 Location bangalore Dec 17, 2012 #2 Best will be a pre-amp processor + power amp combination.
Y yahoo0212 Active Member Joined Jun 7, 2011 Messages 696 Points 43 Location Guwahati-Assam Dec 17, 2012 #3 ANd if you have a lower budget go for Onkyo AVR s .. They are MEANT to giv u that punch and are great for movies... Suggested model Onkyo 717 or 617
H htseeker New Member Joined Dec 2, 2010 Messages 45 Points 0 Location Bangalore Dec 18, 2012 #4 My budget is for a lac for the 5.1...
A AnkurShahi80 New Member Joined Aug 19, 2012 Messages 147 Points 0 Location Mumbai Dec 18, 2012 #5 Hi. Please share your room details for better advice. Kindly specify if it'll be a dedicated room or media cum living room.
Flash Well-Known Member Joined Jul 13, 2011 Messages 1,327 Points 113 Location Dubai/Bombay/Pune Dec 18, 2012 #6 htseeker said: My budget is for a lac for the 5.1... Click to expand... Speakers :- Mordant Short Aviano 2 Fronts - 22k Mordant Short Aviano 5 center - 15k Mordant Short Carnival Bipole - 8k Velodyne Impact 10 - 22k ---------------------------------------- Total - 65k ---------------------------------- Onkyo NR 616 - 30-35k ----------------------------------- Total - 1,00,000 Alternate speakers - Polk Tsi Series Alternate AVR - Yamaha
Kittu New Member Joined Apr 5, 2010 Messages 5,349 Points 0 Location bangalore Dec 18, 2012 #7 Flash said: Onkyo NR 616 - 30-35k Click to expand... Tada!! are you quoting the US price?
denom Banned Banned Joined Mar 11, 2010 Messages 3,129 Points 0 Dec 18, 2012 #8 Yamaha Aventage 1020 - 75k Pioneer SPK51FS 5.1 Pkg - 48k Total- 1.23L, yea I know over your budget, but a set-up you will be satisfied with for a good while.
P push New Member Joined Aug 4, 2008 Messages 56 Points 0 Location Noida Dec 18, 2012 #9 Which speakers are these?? tried google but no results denom said: Yamaha Aventage 1020 - 75k Pioneer SPK51FS 5.1 Pkg - 48k Total- 1.23L, yea I know over your budget, but a set-up you will be satisfied with for a good while. Click to expand...
denom Banned Banned Joined Mar 11, 2010 Messages 3,129 Points 0 Dec 18, 2012 #10 push said: Which speakers are these?? tried google but no results Click to expand... SP-PK51FS - 5.1-Channel Speaker Package | Pioneer Electronics USA
haisaikat Well-Known Member Joined Dec 12, 2010 Messages 2,888 Points 113 Location Kolkata Dec 18, 2012 #11 The cost associated with cables (5 to 10 K) and source (BD Player, etc) must also be accounted for.
